Текущее время: 25 июл 2025, 05:01
COWON D3 Firmware V x.33
Сообщение COWON D3 Firmware V x.33
Дата выхода: 01.04.2011
Список изменений:
Video Player
  • Improved fast forward playback: support up to 2.0X (This function may limited to some high resolution video files.)
  • Added file sharing option (Tap and hold on the file name and select "Share" in file list.)
  • Added manual settings for subtitle encoding and locale.
  • Improved playback feedback of jumping to certain location by touching.
Music Player
  • Improved fast forward playback: support up to 2.0X.
  • Added file sharing option.(Tap and hold on the file name and select "Share")
  • Improved displaying file list faster even many files are contained in the list.
  • Improved to play FLAC files which contains error in Meta tag.(Update Media Database to apply the improvement. Settings>Privacy>Media Database update.)
  • Fixed the noise that occurred while skip files with Bluetooth connection.
Paint
  • Added multi touch drawing.
Documents
  • Diversified option of encoding text.
  • Japanese(Shife-JIS), Japanese(EUC-JP), Chinese(GB2312), Chinese(Big5), Latin 1(ISO8859-1),
    Russian(IOS8859-5), Latin 2-encoded font used in Central and Eastern Europe(ISO8859-2),
    Greek(ISO8859-7), Baltic(ISO8859-4)
Comix
  • Fixed the error that scroll stopped occasionally.
Wi-Fi
  • Fixed the error that AP connection was failed occasionally when the device was on from sleep mode.
Task manager
  • Added function of 'Running list', 'Installed list', 'Memory Cleanup'.
Etc
  • Improved stability.
Ссылки с cowonglobal.com:
Скачать европейскую версию (2.33)
Скачать северо-американскую версию (3.33)
Скачать версию для остальных регионов (4.33)
Ссылки с cowonworld.ru:
На русскоязычном сайте публикуются прошивки 4.x
02 апр 2011, 12:57
Сообщение Re: COWON D3 Firmware V x.33
Чуть позже добавлю зеркала с форума.
02 апр 2011, 12:58
Плеер: Cowon Z2 8Gb White
первоапрельская прошивка :wink:
03 апр 2011, 10:05
Плеер: HM 601 slim
Наушники: T-PEOS H-200
а что означает - Class A, после номера прошивки, в инфо о системе?
03 апр 2011, 13:12
Плеер: Cowon D3
Наушники: sennheiser 300-II
чот на ковон раше не появилась новая версия до сих пор((
12 апр 2011, 17:56
Ololo
На Ковонрашу забей. Ее курирует Blade, официальный дистрибьютор еще over 9000 брендов, включая Audiotechnika и Ritmix.
12 апр 2011, 18:03
Плеер: Cowon D3
Mr. Vladimir писал(а):
Ololo
ок)
15 апр 2011, 08:34
Плеер: Cowon C2, i10
Наушники: Phiaton 500
Появилась на русском сайте:
Усовершенствована функция ускоренного просмотра/прослушивания медиафайлов (скорость увеличена до 2х)
Добавлена возможность расшаривать файлы.
Добавлены ручные настройки субтитров.
Усовершенствовано перемещение по видеофайлу по «тачу».
Увеличена скорость загрузки большого списка файлов.
Улучшена обработка FLAC файлов с ошибками в тэгах.
Устранён шум, возникавший при пропуске файлов при Bluetooth-соединении.
Добавлена опция «многотачного» рисования.
Модифицирована опция кодирования текста (в т.ч. для русского языка - IOS8859-5)
Исправлена ошибка остановки прокрутки комиксов.
Исправлена ошибка подключения по WiFi после выхода из спящего режима.
В менеджер заданий добавлены функции 'Running list', 'Installed list', 'Memory Cleanup'
Повышена стабильность работы устройства.
Для умного дурака ни одна защита от дурака не преграда...
Colorfly C4 Pro, Cowon С2, Cowon i10
Наушники: Phiaton 500, 400, 320, FA-011 mod.
15 апр 2011, 23:47
Плеер: Cowon D3
когда же будет след обнова? или типа всё? плеер робит идеально?
11 июн 2011, 14:09
Плеер: HM 601 slim
Когда сделают.
Только я так думаю,уже будет глобальная прошивка
11 июн 2011, 15:32
На корейском сайте уже есть 1.52 прошивка, думаю, что скоро и на cowonglobal она появится. И обновление обещает быть жестоким, судя по картинкам...
12 июн 2011, 00:56
Плеер: Cowon D2&D3
DiveSlip
Я так понимаю ты об этих скринах ? (http://translate.google.com/translate?h ... 26no%3D820)
Там че обновят андроид до 2.3 ???
12 июн 2011, 22:57
Плеер: Cowon D3
Наушники: Sennheiser HD438
Блин, народ) Читайте мою тему=) Корейцы с февраля юзают прошивку на андроид 2.3.3=) Можете и вы её установить. Го сюда, я там рассказываю что да как.
viewtopic.php?f=65&t=4680
Добавлено спустя 2 минуты 42 секунды:
Я уже на этой прошивке и мне нравится. Один недостаток, я так и не понял после запуска какой программы мп3шник перестает уходить в спящий режим. каждые 30 секунд экран включается, показывается анимация отключения экрана и экран сново отключается, через 30 секунд повторяется снова. но такое происходит после запуска какой-то из корейских прог.
Сканирование медиа внутренняя память начато. Во время сканирования другие процессы могут выполняться медленно.
Пффффф.....
13 июн 2011, 09:43
Плеер: Cowon D3 plenue
Наушники: Sennheiser HD 203
Я, пожалуй, лучше подожду, пока администраторы выложат новый Firmware.
13 июн 2011, 12:21
